Need for speed
Many factors effect a given sailboat’s pointing ability and speed upwind. Proper headstay and headsail halyard tension is at the top of the list and unfortunately, difficult to achieve with the rig on water ballast Hunters. As a remedy to this problem, has anyone ever fitted a pair of running backstays?While I am asking, does anyone have knowledge concerning retrofit of a centerboard trunk fairing to “clean-up” the underwater profile of their boat? This opening surely causes a great deal of speed robbing turbulence and the fix should be quite simple, just glue a strip of Mylar with a slit in it over the opening. The ballast discharge problem should also be addressed in a similar fashion.
