We installed hardwood flooring in the new house 5 years ago and had some pieces left over.
The hatchway saddle board and tiller stick were "WO" (white oak) and badly damaged/worn. The saddle board obviously a different species than the OEM teak trim boards. Further, the hatch slides were cracked and damaged and the hatch slide-lip(s) damaged as a result.
I decided to make replacement pieces out of the "BC" (Brazilian Cherry a/k/a Jatoba). The wood is twice as hard as WO and has awesome longitudinal strength. Based on me standing on a single 3-footer, spanning two 5-gallon pails, using it as a replacement stick seemed a cheap way out.
Most impressive of all - A: it's cheaper than dirt! B: it's gorgeously figured.
Unfortunately, it's hardness is partly derived from it's high silica content. Likewise, the factory finish is impervious to my orbital with 60# and had to be burned off and scraped with a torch.
The silica had my cabinet-maker friend hesitant to run the boards thru his planer and after the first time out, refused to do any more - despite the free lunch!
If anyone's interested, here's the old WO stick, and the BC replacement.
The last 3 photos show the flush-mount plate relief, how to varnish a hole and last, the grip area contour.
