Teak trim replacement
Aug 1, 2016
2
Catalina 30 Port Sanilac Mi
I have a 78' Catalina 30 with the compass and depth sounder mounted on the cabin bulkhead, With wood rings backing them. I would like to replace the wood rings. Anyone know where i can find replacements? also the wood boarding step and the coming around the cockpit cubby hole
Jan 6, 2010
1,519
The easiest if what you have is teak would be to substitute Starboard or faux style PVC wood.
Then have a local shop circular cut your pieces.
CR
Jul 14, 2015
840
Catalina 30 Stillhouse Hollow Marina
Catalina Direct has a teak supplier again. Contact them and let them know what you want.
kito
Sep 13, 2012
2,011
1979 Hunter Cherubini 30 Clemmons
Did you try Catalina Direct?. Not sure about the rings and step but I bet they have the coaming hole trim. For the others, maybe improvise and buy some teak and make them yourself or like Captnron said, have someone do it for you.
Ooops...John beat me to it ;)
