The teak below the forward deck cleat has split. I believe it's because of some sort of corrosion expansion of the threaded studs that are used to mount the Deck Cleat. does any one have experience with this? I initially thought that I could just replace the cleats and Clamp & Glue the teak but I cannot find the correct size cleats. all the Shaefer or Dog Line brand cleats offered thru the website store are either too long or too short (12" o4 10", I need 11 1/8")and the span between the two mounting studs (existing cleat is about 3") are to far apart.
Am I on the right track as far as corrosion being the cause? does any one know where the correct deck cleats were sourced?- are they still available? If not, can the corroded threaded studs be removed from my existing cleats and replaced? any help would really be appreciated. I have not removed the cleats yet as my boat is in the water and tethered with dock lines attached.
