Starting my spring worklist:
I stored my B323 indoors this winter so everything would get good and dry. I've had a continual problem with the "teak" seating surfaces...they get water under them and if someone sits on them the get a wet rear from the water squeezing out between the wood surface and the underlying fiberglass.
The last 2 years I've recaulked the edges completely, but still have a the problem. Its partly the result of the seating surface becoming detached at the edges and I cannot figure out a way to completely detach the seat surface without ruining it. The reason I want to get it off completely is so that I can clean the accumulated crud from beneath it then re-bond to a clean fiberglass surface. The wood itself is in fairly good condition, and I don't want to replace it if I can find a way to solidly reattach.
Any suggestions short of getting a new boat with no exterior teak on it would be appreciated.
I've got all of the old finish off the wood and am still debating whether to put new finish on or just keep it clean and let it weather. I hate the look of Cetol and a good varnish job is a lot of work.
