Teak & Holly
107
Beneteau Oceanis Boca Raton, FL
Ok, I made my decision to use teak & holly plywood. The vendor has unfinished at $200 a sheet, and finished at $341 sheet. Finished is teak side only, so sealing the bottom and edges will still be neccessary.If the forum would like, I can try to post pictures as I move along. My question is what product to use on the unfinished version for top, bottom, and edges. I am thinking west system epoxy, three coates on all sides to seal the wood. Then three coats of varnish to finish the teak & holly side. W.S site says the 406 hardner is not suited for clear coat. This makes me wonder if it should be used on the teak & holly side. The 407 is much more expensive, but says it is for clear coat. I will have to apply this with brush or roller as I do not have skill or equipment to spray. Will the roller give me a nice finish on the teak side? Oh, on the price of the wood, I think it will be less if I do the finishing, even with the amount of materials needed. Am I right, or have I missed something?
jimq26
Jun 5, 2004
860
Here's what I did to get great results.
Use epoxy on all edges and the bottom. Use a couple of coats brushed on to completely seal it. Teak & Holly surface - I used 7 coats of the best clear varnish you can find, applied with the best bristle brush you can find. You're going to be happy with the finish.
Dave Groshong
SBO Staff
Staff member
Jan 25, 2007
1,867
Catalina 22 Seattle
I would coat the sides
and bottom with penetrating epoxy. Finish the top with 7 coats of Crystal varnish.
May 1, 2005
107
west system
Is it neccessary to apply the epoxy to the teak veneer side? Is West System 105 considered penetrating?
