Scott, not a joint...an overlapping piece. Glued on. I also come from construction, in my early years I worked for a commercial builder. I have built 2 houses of my own, entirely by myself, from concrete to finish trim and cabinetry, and I am here to tell you, "Laminate".
The piece in the video is from the door trim extending to the right about 2 inches. Yes, you can see the seam vertically from floor to ceiling. This is not a flat butt joint of two pieces, but rather, the 2 inch piece is laid "Over top" of the first piece. No joint. Additionally, if this were veneer, with an exposed edge from ceiling to floor, how long do you think that edge would last? An exposed veneer (millimeters thick) running vertically, with people touching it and rubbing on it would last about 15 minutes.
I agree that the older boats are veneer...my 84 included. I am also not saying ALL new Hunters are laminate, because I simply do not know... but what I can tell you is that THIS particular 33 has laminate on the walls. I was told by my dealer that the E36 that they have also has laminate on the walls.
As far as Eddie saying it could have been a "One Off" for the show... No way. Yes, they do custom work, I agree...but not rushing to get a boat put together with laminate of all things.... just to get it to the show... Also, this particular one is out of dealer stock here in Ohio...
Now, just to be clear.... I am personally "OK" with this. Real wood does require maintenance... so this is a great answer. I am doing my entire boat in "Oiled Cherry" laminate. My boat showed its age, scratches, gouges etc... so this was a logical answer to update my boat to have a look of something newer. By installing laminate on all of my surfaces, does it make my boat a "Plastic" boat... yes, it does. But, with me having 2 kids, 5 and 2 years old fingering and scratching everything up, it is the closest to bullet proof I could come up with. I totally agree that "TEAK" is the nautical wood of choice, and if you have a boat built with it, it is beautiful and "Genuine" But, if Hunter is doing this on some newer models, I am sure it is simply to keep cost down, not only during the manufacturing stage, but from a purchase standpoint, as well as lower the maintenance required by its owners.
These are just my own personal observations and not meant to be offensive, as I love my Hunter with or without laminate....
