teak cleaners/brighteners
John O'Donald
Do teak cleaners/brighteners remove island girl products or poly glow?
Jim WIllis
Should'nt, but depends
Poliglow is an acrylic. It is removed by solvents and ammonia. Island Girl is a system of several components, with organofuntional silicone in one sealant, 3 special resins in another (MH Superglaze) and a non-carbon-based wax in the SB Superwax. These are removed by IG cleaners or xylol-based solvents. Teak brighteners are usually oxalic acid-based and should not remove the above surfaces. As for the cleaners, depends if they are solvent or detergent based. If they have caustic in them they could also be damaging. Hope this is of some help. but to be careful , always rinse off immediately if you think that a surface can be damaged. Thanks Jim W
