TD,TS,PTC Emily
JamesG161
Feb 14, 2014
7,945
Hunter 430 Waveland, MS
A new description for a Tropical Disturbance...
Post Tropical Cyclone [PTC]
At least for me:rolleyes:
PTC Emily appeared, went to 45 mph winds :yikes: for, let me calculate...
Wait for it....
3 HOURS
_________
High Pressures currently over SW USA will push PTC Emily out into the Atlantic as it dumps cooling rains on Florida, reducing sea temperatures in its track.
_______
Dang we had one of those here on the Gulf Coast about 3 weeks back that lasted 5 hours and didn't get a Name.:confused:
________
There is some activity off West Africa but there is little concern at the moment.
Jim...
Thanks for the update James.
May 24, 2004
7,202
CC 30 South Florida
I got a call from Spain from a friend of ours asking about storm Emily. His phone gave him an alert about storm weather in Tampa. I responded with a text message, " it seems to be a rain event with some minor localized flooding, hardly any wind; have not checked on the boats but do not anticipate any problems" That was my "boat shoes on the ground" live forecast. The answer to the question why it became a named storm so quick is because of CTA. These are heavily populated areas and it allows them to broadcast more serious warnings so that they can cover their a___s. Not too long ago a storm ripped in the middle of the night with no warning and caused some heavy damage. The "No Name" storm caused the weather forecasters to catch a lot of flack.
Likes: JamesG161
JamesG161
Feb 14, 2014
7,945
You can say in this forum...
aNKLEs and no need for a___s.;)
You all should check your boat and properties Insurance... Wind Deductible for NAMED STORMS.:rolleyes:
Oh well...
_____________
PTC Emily update and current Atlantic and I do a quick glance each day using this example for Aug 3
A few easy indications that I use for long term movements and potential Intensity[ACE]
1) Small blue arrow showing the High Pressure Fronts. {General movement ESE]
2) Path of PTC Emily with the Satellite overlay. The Low under the P in PTC Emily is the center.
3) The PTC Emily flows(pushed) in the trough between the Two Highs.
4) The light blue arrow shows the normal West African birth place and historical paths and that path would be over Cooler than normal waters indicated by the blue Oval.
5) The Orange Arrow is where we are getting the West African potentials, this season. The waters down there are slightly warmer than normal. So far, not tropical waves but just plain old storms.
Good News...
Nothing for next 10 days from Africa.
_______
My Pacific Attempt...:doh: for @jssailem
Highs Dominate the West Coast of USA, so fair weather.
Tropical storm potentials are spinning off Southern Mexico and Central America[Like Africa] but nothing Tropical in next few days.
Jim...
Thank you for the update and weather lesson. Sailors need such information if they plan on sailing for more than a day or two in open waters. The graphics sure help to paint the picture. When the two Highs close on each other does that influence the winds in the low? Speed up or tear apart and disperse?
JamesG161
Feb 14, 2014
7,945
YES to both!
The "Speed Up" is what you might imagine if it were Water Waves, The higher the wave height (pressure) and the Closer the Waves the faster you would "surf" between them. The "tear apart" would happen by restriction (pinching) of the Counter clockwise tropical motion, thus minimizing spreading wider and intensifying.
Jim...
Thanks. Ive been reading about compression zones in the areas around the north side of New Zealand. How the weather patterns are influenced. Your image showed that structure. Suspect the storm formations off of the African coast get influenced in the same way and pushed West towards the waters of the mid southern Atlantic.
Likes: JamesG161
JamesG161
Feb 14, 2014
7,945
Think of swirls and eddies in water. As the spinning of the Earth pushes the winds near the equator to the West, the North and South Hemispheres winds [ ESE ] spins and swirls to fill in behind the equatorial winds heading west.
Thus we get counters clockwise Eddies in the Northern and Clockwise spins in the Southern Hemisphere.
There are many more "spin effects" and in addition the Pacific and Gulf Streams water flows. Add to this the Jet Stream and modern computer based models are Born.;)
Jim...
PS: Engineers study these type flow patterns and eddies in Thermodynamics and Hydrodynamics for mixing fluids and making stuff in tanks.
Thanks... My background in fluids has been far more experiential than academic studies since Geology in College.
JamesG161
Feb 14, 2014
7,945
Next time your are motor cruising in calm water, look astern at the swirls and eddies.
Your boat is the "earth spin" as the bow makes a Hole in the water or West wind Flow at the equator.
As the "winds push forward", the water must fill the hole in the water left by the boat.
So...
As the water flows to fill the boat's hole, they flow the opposite direction of the boat and Swirls and spins.
Also note the Port side eddies spin in the opposite direction from the Starboard side.;)
Water is a liquid and air is a gas but...
Both are fluids and act in the same dynamic ways.
Jim...
Yes. Important structure for Fly fishing in our streams up here. Creeks, rocks, eddies, fish feeding.
Likes: JamesG161
JamesG161
Feb 14, 2014
7,945
Fly fishing
Great example. I grew up vacationing in Colorado and loved the dry fly dropping right where the Rainbow trout waited as the swirl pushed that fly into his still water vision.:hook2:
Then my Grandma cooking on a wood stove, the fresh trout (with trout gravy), hash browns, soft scrambled eggs, and the lightest biscuits known to man at the +8000 foot mountain cabin.
MMMM mmm MMMMMMM.
Lunch time.:biggrin:
Jim...
3
Bayliner 25 Miami
Hey, these updates are really useful. Such type of storm can strike anytime, we need to take precautions and prepare for it. Many accidents occur due to the tropical storm that causes a lot of damage. My friend recently faced such accident, he had a boat insurance Boca Raton that helped him overcome the loss and the insurance gave him a full property, replacement and medical coverage. The best way to prepare for it is to find more from experts and get the best boat insurance policy plans.
Kermit
Jul 31, 2010
5,720
Here’s my experiential background in fluids.
(Thanks for the graphic!)
