Taper pins
May 30, 2006
1,075
Oct 2, 2005
465
I replaced mine about a year ago. I should look at it again because I suspect they don't last very long, and I should have gotten more than one spare. The part is available in the States from McMaster Carr. The part number is #90681A293 and described as a #4 X 4" stainless tapered pin, .167" small end diameter, .250" large end diameter. The taper seems right but the pin is long and will need to be cut short after being driven home.
Craig Tern #1519
Jan 28, 2001
694
Wow! I've been off line for a few days (work). Spending most of my free time working on Lyric with the intent of undoing the ravages the Mexican sun did to her. Goal is to be in the water by the end of the month. Anyway, got on line to know if anybody has a source for tapered pins and find the information! Question though, which end has to be cut?
Thanks Craig! Walt
To: AlbinVega@yahoogroups.com
Date: Fri, 10 Jul 2009 00:44:39 +0000
Subject: [AlbinVega] Re: Taper pins
Craig Tern #1519
Nov 8, 2001
1,818
Hi All
Believe me the tapered pin is noty needed. Having broken quite a few due to the tides here in teh UK and my Vega drying out I have now removed teh tapered pin for the last four seasons. Much easier
Cheers
Steve B
Oct 19, 2019
921
Albin Vega 27 Limerick
Hi Steve and all.
Following Steve's advice I don't bother with taper pins - mine has been
broken for some time.
I do check after a sail in strong winds that the rudder post has not
slipped. It hasn't yet but I keep the Allen key to hand just in case....
Question: the bronze base bolted to the cockpit sole (through which the
rudder post passes) is not "centred", ie not aligned exactly with the axis
of the boat.
Is this normal? Compensating for the geometry of the rudder??
Thanks
John V1447 Breakaway
John A. Kinsella Ph: +353-61-202148 (Direct)
+353-61-333644 x 2148 (Switch)
Mathematics Dept. e-mail: John.Kinsella@...
University of Limerick FAX: +353-61-334927
IRELAND Web: John Kinsella's Website
Oct 2, 2005
465
Hi Walt, After driving the pin tight both ends will need to be cut with a hack saw and cleaned up with a file. Perhaps if I keep an eye on the hex bolt this one will last.
I also have not been able to take the boat out for some months as the mast was in my front yard, but she's back together now and I just came back from an afternoon sail. It felt great.
Craig
Jan 28, 2001
694
Thanks Craig! Walt
Date: Sat, 11 Jul 2009 04:00:18 +0000
Craig
