I am currently repowering a 37' O'day center cockpit. I am cleaning up the engine compartment and laying it out as best I can to make it easier to maintain the Yanmar that is going in. I bought the boat with no engine or fuel tank. The battery tray was also gutted out.
My issue is that if I mount the gas tank in a small space adjacent to the engine (starboard side 16" x 42" shelf), the tank will make it difficult to access the starboard side of the engine.
On this model O'day it has two water holding tanks that are on the port and starboard sides inside the engine compartment. They are butted up against the side of the hull. They hold 75 gallons each and are tied together, so they drain simultaneously.
What I am thinking of doing is removing the starboard tank and replacing it with a 50 gallon diesel fuel tank. This gives me more space and flexibility on what to use the new shelf for. Right now it would seem that 75 gallons would be sufficient water capacity for coastal use.
My only reservations are that I may throw the balance of the boat off as I burn off fuel and or that I might regret losing the 75 gallon capacity.
Would appreciate any feedback regarding this issue.
Thanks
Thanks
