Tank Gauges
K
Keith
Has anyone installed tank gauges that work? If so which manufacture? I would like to install a fresh water, holding tank, and fuel(diesel) gauge set. Any suggestions would be helpful. Thanks
Tim McCarty
Check out Accuguage in the chandlery...
I think it's still there...I've got them on my boat, and they work well.
Dick McKee
We've owned several boats and Accuguage
has worked the best and IMHO are very reliable. If you have plastic tanks I think they are the way to go..
Jim C
Jun 18, 2004
63
Catalina 30 Tulsa, OK
In the process
I'm currently in the process of installing the Accugage system on my C30. The PO had purchased it but didn't complete the installation, now I know why. Without removing the hoses from the tank there's no way to lift it to install the foil strips to the side. What I'm resigned to doing no is to cut the fiberglass wall on one side to gain access to the plastic tank. One other thing I've found is that the system is preprogrammed from the factory, so if you want to make any changes you have to send it back to them for updates. All in all, I think I'm going to be happy once the install is complete. Good luck, Jim
Dec 23, 2003
268
Hunter H31 83-87 Captain's Cove Bridgeport, CT
Accugage
http://www.sailboatowners.com/upload/display.tpl?folder=73223824545&fno=17
T J Furstenau
Accugage Alternative
From the archives - http://archives.sailboatowners.com/pviewarch.htm?fno=0&sku=2006023073825.4&id=378629&ptl
