I posted a little while back about having rain water in the bilge under the sole in my Hunter 22. I was able to locate the leak, it was the anchor locker drain. Put some 4200 in there and no more water in bilge.
Fast forward 1 month later to present day. I just got the boat in the water for the first time since I bought it late last fall. I rented a slip at a marina for a week and everything seemed to be going ok, except for some motor trouble. I was very concerned with the sink drain thru-hull fitting leaking, and I've been constantly checking it for signs of leakage of which there's been none. However, I neglected to look in the bilge under the sole until tonight as I was investigating the installation of a bilge pump. Bam, water. Trying to figure out if it's brackish or rain water, it just rained today. But there was no rain leaks the week prior to launching... which makes me think I'm leaking from... what? The keel bolts?
So I thought maybe the anchor locker was leaking again, but it's not. However, the transducer is got some wet spots around the threading (picture attached). Does not look like enough water to have filled the bilge, but now I'm freaking. I plan to pull the boat back on the trailer Saturday. Any ideas about the leak?
