I was wondering if anyone has had issue or advice on taking on water at the rudder tube. I was out yesterday and discovered water coming in at the base of the rudder tube. It appears that after removing the access panel below the most rear lazerette cover where you have access to the steering cables there was water coming in at the base of the rudder tube inside the boat. Is there a fix for this, and if there is can someone advise.
