Don,I have a quick question. I do have your book but it is at the boat. I am new to sailing (about two years). We have an O'Day 25 and I lake sail in northern MS. My family and I were sailing last week in around 15 - 17 mph wind coming from the NNE with gusts. The lake we are on is basically a big rectangle lying NE to SW. Our marina is at the most SW part of the lake. The were white caps. Normally I put up the 150% Genny but with the family (they don't like to heel as much as I do) and the weather conditions I put up the working Jib. I have only used the Jib once before in the past 18 months. I flattened the main and we were off. The boat handled great. I tried to run as much as possible on a beam reach but with the wind moving around I was more on close reach as we went across the width of the lake (around 3 miles). I also spilled the main as much as possible to keep heeling down. Here is my issue:When I was on a starboard tack and tacked the boat into the wind to go on a port tack everything went without a problem. When I was on a port tack and tacked the boat into the wind it took 2 or 3 times to get the nose turned. We went back and forth across the lake many times and I always missed the tack to go back on the starboard run but never the one to go on the port run. I rarely if ever miss a tack with the big 150. What I normally do when tacking is after the tack order is given, move the tiller over and release the Genny. It takes a while for it to sweep over. I did the same with the little jib but of course it takes less time for it to move over. Should I wait to realese the jib unitl the nose is almost dead in the wind? Why did I miss the one tack and not the other? Boat speed was very similar on both tacks.Thanks.Scott
