Mates: Please review my response to Ms. Hillary. How come the gals ask such interesting questions?!!!The piece I left out was fairlead adjustment. Most sailors don't bother with fairlead adjustment and that is too bad because the fairleads control EVERYTHING on the jib.How you determine the correct fairlead adjustment is simple. The jib trimmer on the loaded sheet is watching the jib as the boat comes head to wind. What he is looking for is how the sail "breaks". It is much easier to see this when someone shows you what to look for as it is happening but I'll try my best to describe it. What the trimmer is looking for is the foot to flutter, the bottom to luff or the bottom telltales to break. If any of that happens, he tells the other trimmer to move the fair lead AFT. If, on the other hand, the leech flutters, the top luffs or the top telltales break, he tells the other trimmer to move the fairlead FORWARD. How far forward or aft - I don't know, maybe 1 or 2 holes. You have to experiment. To check if you have the correct setting just tack over and see how the sail breaks. You don't want to do that under normal conditions but you should while your practicing.The goal is for the sail to break evenly from top to bottom. This rarely happens but you want to get as close to it as possable.You want to perform this exercise on every tack. Why you ask? The reason is that if the fairlead is not set correctly you can mess with the controls all day long and you'll never get the sail set correctly.If you have pin type fairleads, this routine is a little more difficult but not impossable. The trimmer just has to be ready. He isn't doing anything at the time anyway. If you have a Garhauer adjustable fairlead system it is a snap.Does everyone understand what I'm describing here?
