Hi, My question pertains to tacking in strong winds (12-18 kts). We previous owned a MacGregor 25 water ballasted and we could do no wrong. Sailed in heavy winds (12-18 kts) and had a blast! We purchased an older 1984 MacGregor 25, not a water ballasted boat, and in heavy winds (12-18 Kts, -what I would consider heavy) we can't seem to get her tacked and around, will bleed off even when we have speed to get through the tack and will lay way over and barely move. Sometimes end up jibing when we really don't want to! She'll lay down on her side before turning into the wind. We've tried doing different things with our sails such as reefing the main and only sailing with the main, having the main very flat. Tried bringing in the jib so it's not so large an area if we try to use it too. We used to have fun sailing, had a Windrose 18 and the water ballasted MacGregor 25, and a Montgomery 15, and never really spooked ourselves. This current boat is a challenge. Any thoughts on how we can correct our problem? A friend who sails a Catalina 22 at the lake mentioned that the rudder is too small. I'm thinking that we are also sailing in to strong of wind for this particular model.Thank you! Jill ( I hope I am using proper terms, still learning)
