Tachometer
Jul 6, 2010
28
Catalina 30 Bainbridge Island, WA
For some reason my tachometer RPM needle is not functioning properly. It tends to jump around, or not work at all. The hours meter works fine. I just installed a new alternator but the problem still exists.
Thank you in advance.
Jan 5, 2017
2,463
Could be a poor / dirty connection on the tach or the back of the alternator. I’ve had the same problem and solved it by cleaning connections. Worse case is you need a new tach but I think cleaning will fix things for you.
  • Helpful
Likes: Ward H
Jul 6, 2010
28
Michael,
Thanks for the tip. I'll tackle that next and see if it works.
Tom
Jan 5, 2017
2,463
Worked for me Tom. My brand new tach is still in the box. Should have cleaned those contacts before I bought it.
Jul 6, 2010
28
No luck yesterday Michael. I cleaned the contacts as you suggested, but now I wonder if I have the tach lead on the wrong pole.
Rick D
Jun 14, 2008
7,189
You are smarter than I. Mine was jumping around and then quit. (Mine is driven off a flywheel magnetic sensor.) I cleaned up the contacts and checked the back of the tach. Nothing. I ordered a new tach (new old part). Nothing. I got a new sensor. Found out I have to remove some parts to get a wrench on it. Put everything back together. Now the tach works. Geesh.
