Bob Robeson
The tack on my C-36 with Universel M-25 engine does not work. I have tried 3 different new ones with no luck. These are the kind that hooks up to the Alternator. I have made sure the wiring is good via a ohms meter and verified that the AC is good and it is the same as other Universel Engines, about 30 volts AC. So if all the voltages check out but the tacks don't work, what am I missing?
