Tachometer Quit Working: 1985 Catalina 30
Mar 29, 2017
9
Catalina 30 Everett, wa
Tach has quit working and I'm trying to work out if the problem is wiring or the instrument. I did check the wire connections on the back of the tach and on the starter and they appeared good (previously a loose wire on the starter was a problem). Then - and this is the question - I ran a spare wire from the starter to the back of the tach thinking this would be a good way to see if the problem was somewhere in the original wire. Tach needle did move but still didn't work. Was this a good check to run the extra wire and does it mean the problem is the tach itself? I'm no electrician so please comment or offer solutions. Thanks. Steve
May 20, 2016
3,015
The tach wire goes to the ac or w terminal of the alternator not the starter.
Les
Wow Les.. I got it right. Some of your wisdom about Catalina's may be rubbing off. ;)
