Tachometer problem-goes too max and just sits there the entire time. How to check alternator output
Aug 16, 2010
1
Beneteau 343 Rock Hall, MD
Tachometer goes to max and sits there full time after engine start. How to check alternator output or other possible solutions.
May 20, 2016
3,014
Have you tried adjusting the pot on the back of the tach ( small hole straight slot screwdriver). If that can't bring it down you probably need a new one. To really check you need either a o-scope or frequency meter.
Les
Dec 19, 2006
5,809
Hunter 36 Punta Gorda
I had the same problem or at least tack going crazy all over the place and some times calms down and works normal but not always and most times is crazy and new Yanmar tack made by VDO $$$$$$$$$
Found one VDO for $99.00 but it still goes crazy.
Nick
May 20, 2016
3,014
on my project list is to epoxy some rare earth magnets to the flywheel - and use a hall effect sensor to pick up the pulses - should be a cleaner signal than the alternator.
Les
Nov 6, 2006
9,885
The older Yanmars did that with a prox probe counting flywheel teeth which works fine until the old tacho starts loosing its mind.. Don't know what engine you have.. ?
