What I do.
After reviewing what others have done; cut it down a bit and engineer a seperate piece of material to keep the v-berth a good size, raise it to the roof with a pin drilled higher up on the post, turn it into a drop-leaf arraingement, I decided to just keep it turned around in the v-berth position all the time. It frees up space in the salon, at least four people can still dine, and you can still turn it around. You can check the archives also. alan
