T Off A Through Hull; Red Brass Issue
Rick D
Jun 14, 2008
7,206
OK, guys, a few years ago, I would have purchased a bronze T and a nipple to connect it to the thru hull. Now, however, I am constrained by the fact the nipples are only available in Red Brass vs. Bronze. Now, red brass is supposed to be acceptable for salt water use via the documentation I have read (assuming of course, proper alloy). However, there appears to be an issue using red brass with bronze. I don't know how much of an issue this really is with respect to red brass compatibility(vs. yellow), but it's enough to stop me. So, I don't want to use a plastic nipple, so I guess I'm stuck with just putting a T in the hose which doesn't thrill me at all. If the only acceptable answer is to put in another through hull, I'll skip the whole thing. I gotta believe there is a less onerous solution.
2,288
C30 Event Horizon Port Aransas
Are you saying there are no bronze nipples available? OR no bronze T's available?
I would put a T in the hose before I would put two dissimalar metals together. I agree, plastic nipples are junk. What don't you like about a T in the hose? It's just two extra hose clamps more than the T on the thru hull option?
Feb 6, 1998
11,772
Rick,
Groco actually makes BRONZE nipples. You may have to actually order them but they are the only ones who make them. Check their on-line catalog for a part number. They even have a machined wrench surface in the middle..
Rick D
Jun 14, 2008
7,206
I really don't want that stacked on my through hull, Hermitt. It isn't sanitary and I don't trust it vs. a bronze T properly threaded in.
Rick D
Jun 14, 2008
7,206
Rick,
YES! Problem solved. Thanks, Maine. It wasn't in my catalogs and nothing came up on my seach except red brass labeled as bronze.
PS: it was a bear to find. I had to download the catalog since the on-line store does not list them. Wonder why the chandleries don't carry them?
