Beware of synthetic oils
Clark,As was suggested by Steve, I would only use the oil recommended by the engine manufacturer. The only direct experience I have with synthetic oil is a friend used Mobil One in a Ford truck engine right after he purchased it and the results were not good. The engine was using a quart in less than a 1,000 miles in no time. I have an identical Ford truck engine with close to 90,000 miles and it uses practically no oil between changes using the recommended Motorcraft 5w30 weight oil. I think my friend by using the synthetic oil damaged his engine.
