Nah, don't risk it and ...
why would you want to to that?Instead of having the 1-2-B switch decide which battery gets charged, install a PDP at the + side of your house bank, and lead all of the charging sources to that point, and also install a combiner or echo charger and be done with the switch altogether. Once done, you can use that same switch to parallel the banks if you need to do so. Think about it.You have a basic question which can ONLY be determined by YOU as to how your boat is wired, i.e., alternator output to switch or elsewhere? In order to best answer your question, we need to know how your alternator output is wired. Unless we know, all the answers about the switch are meaningless. This is because if the alternator is wired directly to your house bank, AND the ONLY use of the switch is for the output of the house bank, it doesn't matter.If, however, your alternator goes to the switch and THEN to the batteries, then NEVER MOVE THE SWITCH WHEN THE ENGINE IS RUNNING.Buy a book that explains this, my fingers are numb.Buy Calder's Boatowner's Manual for Mech and Elec Systems.Stu
