Josh
These are just some questions I have after reading about the lack of pointability on swing keels when racing...I don't have a swing keel, but I have an O'day 22. In looking at pictures of diffrent makes and models, it looks like the swing keel hasn't changed since its inception. Am I correct in this?As far as wing shape, is the swing keel as it always appears? It almost looks like a two by four that swings down on a rope from a pivot point in a stubby keel. If Im right most are large slabs of iron or lead filled fiberglass, correct?As far as pointability, how does this compare with the 'shoal draft' keel? For obvious reasons the best for pointing would be the full keel right?I was wondering if any company had built either an accordian style of wing? One that instead of just having the slab that drops down, where was a folding flap behind it. After thought, it dawned on me that this would be a bit flimsy and wouldn't produce the best wing shape. Then I wondered about a collapsing wing, where each peice fits inside the next when drawn up. When fully extended this should produce a fairly decent wing. Depending on the strength of the material and the method used to extend and retract it, this could create a large wing and still retain the retractability and shallow draft of a swing keel.Well, just sounding ideas...can you see I was a bit bored today? Nothing to do with the rest of the work day but think about sailing!Josh
