knockdowns
The O'Days have a pivoting centerboard, not a swing keel. The centerboard slides up into a trunk in the keel, it's function is to reduce leeway, not to keep the boat upright. Resistance to heeling is accomplished by the hull form (bigger beam means less heeling) and by the weight of the keel. To a lesser extent, the lift produced by the centerboard moving throgh the water will also contribute to resistance to heeling, but only while moving, and only slightly.The centerboard is made of fiberglass; sometimes there's plywood encased in the fiberglass, and sometimes there's a small amount of lead. My O26's centerboard weighs only about 40lbs or so, and appears to be solid fiberglass.Sailboats with keels can be knocked down quite far by wind, but at some point, the angle of the sail begins to spill wind. Combined with the form stability and the keel weight, this will keep the boat from heeling further. The boat will still heel dramatically, especially in gusts, but it won't be pushed all the way over by the wind.It takes breaking waves to heel a boat beyond the horizontal.
