Swing keel
13
Oday, Northstar 222, Hughes 1000 Elbow SK
I own a 1986 222.
I am in the process of refurbishing the hull and I want to remove the swing keel.
I can't see the pivot pin. Might it be be buried under paint or other material?
Thanks for your help!
JM
Nov 9, 2012
2,500
Oday 192 Lake Nockamixon
The 192 and 222 don't have pivot pins through the keel. Rather, a rod is held in place by wedges either side of the board, which are held in place by SS bars screwed up into the bottom of the keel. Take a look at Trinkka's photo album, I believe he has documented replacement on his 222.
Brian
May 17, 2013
13
Thank you Brian for your very quick response!
Can you give me the link to Trinkka's? I did a search with no results.
May 17, 2013
13
I have found Trinkka, with google.
Than you for the help Brian!
JM
Nov 9, 2012
2,500
Oh, yeah, and JM, here's where I get pedantic. Heh, I think someone else on the daysailer forum was saying the same thing...
Our boats have a centerboard/keel combination. Our centerboards aren't ballasted. A swing keel is just like a centerboard, but it is a ballasted centerboard. The Precision 18, 21, and 23 all have centerboard/keel combos like our O'days. I think the original Catalina 22s have a swing keel. Much more PITA, because you need a winch to lift the swing keel, whereas on our O'days and Precisions, we just pull it up with a line. And we have fixed ballast.
Our boats hold the ballast in the stub keel, and the centerboard swings down out of the stub keel.
On my 15 foot dinghy, it's just a centerboard, no ballast. And on a boat like a Laser or a Sunfish, it's a daggerboard, because it doesn't pivot, it just slides directly down into a trunk, like a dagger going into a sheath.
Then, there's the lifting keel. That would be a ballasted keel that goes up and down in a trunk, a lot like a daggerboard. You can find them on boats like the West Wight Potter 19, the Macgregor 26, a Hobie 20, and a whole host of other racing type keelboats such as the new Left Coast Dart.
Glad you found Trinkka, Joe is a regular poster here... I guess I didn't spell that out well enough!
Brian
