A
Antonio Suescum
I have a broken CB/swing keel. The leash is missing and only have the top have of the keel left. How do I remove the pin to drop the keel for a replacement keel. It seems that the existing pin has to be hammered out or drilled out. Then what should I replace it with? I am also looking for correct dimensions of the CB and length of the line.Thank you,AntonioSt. Pete, FLOday 23 pop-top
