Swing keel on First 20 and ASA First 22
May 10, 2018
2
Beneteau First 22 Abilene, TX
Is it ok to sail with the keel partially raised? I have a shallow area to sail through and would like to know how many turns to raise the keel one foot. What is the best way to lubricate the mechanism. When lowering the keel, it gets hard to turn at about 40 turns. That lasts for 5 or 6 turns then gets easy again. I'm guessing it needs grease? It's a new boat. Any help would be appreciated.
Nov 8, 2010
11,386
Nice boat! And welcome.
My First 260 has the exact same mechanism, just larger.
You can sail with it partly (or fully) up if you want. The sail trim balance will be effected, and you will not point as well, but you can do this if you want to clear a shallow area.
I don't know how many turns to gain 1 foot of draft reduction.
Use a good grade marine grease on the screw. Unwind it while the boat is on the trailer and put grease sparingly on the threads. Screwing it back in will spread it around. Go up and down several times, and look for missed spots. Too much makes a big mess.
A hard spot while turning sounds like a burr on the screw. It would get hard when it hits the nut built into the top of the outer tube. If will probably de-burr over time. A PDF of the engineering drawing of the screw is on my blog here.
https://rarerarebird.blogspot.com/p/260-documents.html
