How exactly is the line for the seing keel fastened to the keel. I plan on replacing the line following the directions posted earlier by swimming under and feeding the line through.scott
Scott - Replied to your last post as if you have a Daysailer because of the heading it was posted under. Which boat you have?Justin - O'day Owners' Web
It wasn't difficult to replace the line attached to the swing keel - you can dive under, thread it through the hole at the end of the keel, and tie a knot. Just be sure the knot is small enough it doesn't bind the keel in the trunk when it is pulled up. The most difficult part was getting the line down through the cockpit tube and out the bottom - I used a coat hanger and some duct tape.RAH
