Swing Keel/leaded centerboard delaminating
I need some advice how to best clean and reconnect a leaded keel in which the lead on the top 2 ½” is separating/folding away from the aluminum alloy fin. What is a good way to eliminate remaining oxidation of lead and aluminum? (I have scraped out all the white crust and gook that has accumulated between the aluminum and the lead, but there is still a film and remaining tiny pockets) What is the best way to “glue” lead back to aluminum alloy fin? A primer and then epoxy? Should I consider melting the lead back to the fin? Has anyone ever done such a thing?
My plan:
First, I believe that the keel is structurally sound; only the top 2”-3” of lead has delaminated from the aluminum. My basic plan so far is just to find some sort of anti-rust like primer to stop any further oxidation and then epoxy the lead back to the aluminum; (squishing it back together with c clamps and the like). I would fill in any cracks with epoxy and filler and grind back excess lead if it does not return to original width dimensions. I will enclose the finished body in a membrane of fiberglass protecting the body from salt water and oxidation. Is this a good plan? Should I consider torching the lead to melt it back into proper position? Any other great ideas?
Details of boat, keel and cause of problem:
Boat and keel: this is a Newport Neptune 16 with a swing keel. The keel has 200 lbs of lead set onto a approx. 4 foot ½” x 14” aluminum centerboard (see photos below which show a sample swing keel and shows how the lead is attached to the fin; in the second foto, the keel is broken and shows only the upper section of the lead and how it was attached to the fin; THIS IS NOT MY KEEL).
Cause of problem: I messed up the keel when I repositioned the keel in the trunk by using a higher eye hole on the swivel axis of the swing keel and I did not reset the crib of the trailer to properly give space for the new position of the keel. The result was a boat sitting on the trailer with all rear weight resting on the centerboard. The wood ribs on the trailer were not raised enough to carry the boat and the hull rested on and squished/sandwiched the top 2” of lead on the keel. I have since changed the holding of the boat which allows the boat to properly rest on the trailer ribs…that problem solved.
THIS IS NOT MY KEEL!
Thank you for your help,
sean
My plan:
sean
