Centerboards and keels
Ok - Technically, a board that slides straight up and down is a daggerboard, a board that pivots down to provide lift but not ballast is a centerboard, and a board that pivots down to provide lift and also provides ballast is a swing keel.As far as how far to let it go - Stuart is building boats that are somewhat different from those that O'day built. I don't know why they are recommending hanging the board on the wire, but I wouldn't do it with my boat. It may be that the new boats have lighter boards.The issue with hanging from the wire is that if you manage to make the board swing in a swell, it will begin to shock load the wire and you then risk breaking it. If the wire breaks, the board swings forward at high speed and contacts the stop in the centerboard trunk with a lot of energy. This can actually hole your boat. People have actually lost Catalina 25's for the same reason. If you let the board rest on the stop, not only are you less likely to have it swing because of the angle it will sit at, but if it does swing a bit, it will have less fall and will be traveling with less energy when it hits the trunk.I'd call Stuart directly and ask them what the deal is.As always, your mileage may varry -Justin - O'day Owners' Web
