Keep it down
The information youÕve talked about so far is info that does not pertain to your boat. The idea of raising the keel for down wind or motoring is to reduce the wetted surface of the hull and keel. which causes friction when trying to propel the boat forward. Many boats with keels that Òretract up into the hullÓ can achieve this reduced wetted surface. The Catalina 22Õs keel does not become hidden from view when up in the trailering position, just a little of the top front edge is above the bottom level of the hull. The top end of the keel, the part in front of the keel bolt is now exposed. When in the ÒdownÓ position, this area in front of the bolt is ÒretractedÓ up inside the hull, actually reducing the wetted surface that you see.3 friends, 3 boats, 3 keel problems; Merrit 22, very fast boat, very efficient keel, 700 lbs, takes 2 men and a boy to retract up into the hull for trailering. Hits dock maybe a bit hard, 700 lb keel wants to keep on moving, crushes front of keel trunk and takes on water.Macgreger 26, about Õ88, retractable fiberglass center board designed to break and purchase replacement. Gets tired of replacing and has solid one built. Hits something, jambs new center board into keel trunk, can not get onto trailer, finishes destroying keel trunk trying to remove.Ô78 Balboa 26, very nice boat, very fast, can handle all conditions, swing keel that actually swings up into the hull and a set of doors that come down and close off the slot in the bottom of the hull for a smooth surface, wow!. Has cable too loose, hits stump under motor Keel slides up and over top, slams back down with bottom going further forward and top coming back and destroying this fancy keel slot. Young son says ÒDad I never ever though I would say this, we're going down.Ó Cabin floor and settee had to be cut out to do the repairs.moral of the stories.Catalina has the best keel system (only boat built for over 30 years).Keep keel down at all times except for trailering. Keep just a little tension on keel cable (listen to the hum).Use this site for information about your boat (about dozen very very knowledgeable fellows here).
