Re Snapped Keel Cable
Take a line about 25 feet long and loop it over the bow of the boat. Have two people, one on starboard, one on port, walk the line back to the middle of boat, about 2 feet past the mast, with the line passing under the boat. At this point ypu can now tension the line. Depending on where you may have blocks placed on your boat, you might be able to use the winches to tension the line. As you tighten the line, if you have it positioned correctly, it will raise up the keel high enough you can get the boat on the trailer. You do not want the line too far back as when the keel comes up it will slide of the back of the keel. Experiment - after the second or third try you will get it. Be most sure to secure the line tightly, it will be holding up a lot of weight. Hope it works out for you.Matthew
