A Clearer Picture...
Other 22 owners should jump in here to confirm, but I believe the CB pennent is set-up similarly to my 25. The salon floor pennent hole is the one to push the rod down, to unstick the CB (if indeed stuck). The pennent itself is attached to a clip on the aft edge of the CB and passes through the salon floor exit tube to a pulley or two below the bridge deck and out through a bridge deck through-hull where it is belayed on a cleat. My guess is you will find a CB, but the pennent is missing. You can buy a replacement clip and rope/wire pennent from Rudy at D&R marine, or you can fashion one yourself using a Stainless, long, narrow D-shackle and 1/4" braided nylon line. But you have to expose the CB, by raising the boat off the trailor and lowering the CB. Push the line down through the salon floor tube and attach to new clip. Be sure your knot/shackle clears the width of the CB slot, as you lower and raise the CB.My standing rigging is 5/32", which I believe to be stock for the 22-25 Odays. I believe it is more than adequate for coastal cruising. It is almost never the wire that is the weak-link, in the standing rigging IMHO but usually turnbuckle/swaged terminals/toggles/chainplates that fail due to crevice corrosion. If your at all concerned I would seek a professional opinion, having the rigging replaced if it is at all suspect. Its really cheap insurance. Good luck.Don
