Swim ladder
Aug 24, 2014
160
Aphrodite 101 148 Coeur d Alene ID
any suggestions for a swim ladder now that I mounted an engine on the stern?
Maybe you can fit a small platform to the side of the motor.
I think there is a 4 step ladder often used by scuba diving sailors. Single pole with steps on either side, that is retractable. It might also work.
Likes: PaulK
Nov 30, 2020
79
Macgregor 22 Dania, FL
The platform Jssailem showed is even better if you add a 4-step telescoping ladder to it. Just provide a lanyard of bungie so it doesn't come loose when not wanted.
Been thinking about that swim platform. Would be even better if you could create a way to fold it up when sailing.
Jan 30, 2022
8
Cal 29 Chesapeake Beach
Building on jssailem‘s idea, access at an angle may be nice.
on the other hand now that you’ve done the dirty deed you may as well double down with something like this! Could even fold it up!
Mar 26, 2011
3,841
Corsair F-24 MK I Deale, MD
I built this narrow ladder for my Stiletto 27 using 1-inch square tube, starboard, and Seadog steps. The hinges are wider channel. A boat hook clamp holds it up, easy to pull down. There is no reason the ladder needs to be normal width. The stock ladder went over the side and was a pain.
Likes: FlimFlamII
