Swim Ladder, 1990 Cat 30
Catalina 30 Hampton, VA. VA
Good Morning,
Just purchased a Catalina 30. The owner had taken off the swim ladder. When I attempted to reinstall the mounting flanges on the hinge seem to be too short for the support arms to land on the stern flat and at a 90 deg angle. Does this ladder need to be mounted on board then thru the stern with a backer board? Also where the supports land is now occupied by two thru stern fittings? Any thoughts would be appreciated.
Thank you,
Charlie
Joe
Jun 1, 2004
8,340
call the factory, customer service. Number is available at www.catalinayachts.com
However, I suspect he removed the ladder for the same reasons you're having trouble getting it to fit. If you post a picture someone might offer a suggestion or two. Have you tried locating it on the other side of the transom?
