After 20 years of sailing on other people's boats, and 3 summers of teaching sailing in college using the school's dinghies, I've saved/sold enough to finally afford my own boat. (Albeit just barely.) The survey for which, a '78 H30, is tomorrow.
I've lurked around here for a while and read about the most common issues, but it seems quite a few of her trouble spots have been worked on in the past.
- Complete engine rebuild 2002
- Replaced mast compression post 2002
- Osmotic blisters were ground out, refiberglassed and faired, then epoxy barrier coated 2005
- Rudder glassed and faired 2005
- Awlgrip hull and deck 2005
- New mast wiring 2005
- Custom stainless steel rudder to skeg boot and stem head extension 2005
- Replaced forward lower shrouds 2006
- New forestay 2008
- Jabsco Y-Valve 2013
So my question to you guys and gals is, once I get the report from the surveyor, what sorts of things should be of particular concern?
Thanks for your help.
- New forestay 2008
