Surprise! The engine just quit
Jun 27, 2004
113
Hunter 34 New Bern, NC
We were motoring up the river yesterday when our engine suddenly quit. It re-started easily, and ran for the rest of the day.
I do not like this type of mystery. The engine is a Yanmar 3GM30F installed in our 1986 Hunter 34. Is this incident a wake up call of some sort? Where should I start my investigation?
Thanks for your collective help.
Jan 12, 2011
930
Hunter 410 full time cruiser
well once a diesel is running the only things that stop it are turning off the fuel or the air (assuming you didn't catch a line or net of something and the prop just plain stopped turning).
So as in all things diesel engine - check your fuel system (leaks, clogged filters, water in the separator) as it is going to happen again. Start by checking your separator to see if it is full of water and/or gunked up.
Dec 2, 1999
15,184
I would replace both fuel filters first. We just got back from the BVI's and this was a similar symptom on our generator.
It restarted but quit again in an hour or so. They came out and put in a new filter and it worked like a champ for the remainder of our visit.
If this does not work you will need to do some searching.
Oct 14, 2005
2,191
Ed...
Would bet on an air bubble in the fuel line. Check and tighten all your hose clamps and be sure the engine filter ring is fully tight. Check on the bleed screws as well. Lastly, change your primary fuel filter (Racor or other).
Apr 5, 2011
113
Hunter 34 Tilghman Island, Md
One thing I haven't seen mentioned is to check the vent line on the fuel tank.
Good luck,
Brian
sv Strive
