L
Loren Hall
On Dec. 4 I wrote an article that my genset would not start. I finally got a diesel machanic out ane he figured it to be a fuel problem too. Messed around with fuel system etc. It would act as if it was trying to start but we never got it running.We then took the valve cover off and "what a mess". There was thick black gue around the intake ports, just about plugging them up, when we cranked the engine, there was major blowback from the intake ports. Obviously leaking valves=low compression and it was not going to start any more.The why! 975 hours, 9 years old. It was a predictable outcome. The soundproofing material that had been installed when the boat was built had slowly deteriorated from heat and age and had in many areas turned into kind of a black powdery junk. This had been injested into the air intake which on Northern light generators of this size DO NOT HAVE ANY AIR FILTERING, and relly fouled things up.We pulled the head and will have every thing on track shortly. I pulled out all on the soundproofing material and will replace it, and provide better air circulation to keep the heat down in the fulture. Will try to figure out a way to get an air filter arranged for the little beast. It finally said it was not going to take any more abuse with ingesting sound proofing debris any more.BEWARE EVERYONE ! Most of our sailboats either have rudimentary air filters or don't have air filters at all. And the soundproofing material is getting old and with heat , starts to break down over time. This could cause some major unwelcome situations when we are out cruising.
