Steve W
My 1986 Universal M-18, (14 hp FWC) diesel is surging 100rpm at any setting between 1400 and 2000 rpm in gear. No surging in neutral at any rpm, and no surging below 1400 rpm in gear. Fuel is clean, filter is recent, checked the coupling alignment and motor mounts look ok. The only things left I can think of is a bent prop, bad cutlass bearing (was fine in January) or the engine governor has gone bad. There is a vibration between 1400 and 2100 rpm (in gear) that fades a little above 2100rpm. No vibration in neutral. Do I have twp problems or is one problem causing both symptoms? Any ideas? Thanks in advance!
