More specifics
In my model I track:
a running total of AH into the bank
a running total of AH out of the bank
voltage history
current voltage
the current current flow
battery temperature
I'd use basic math and some sophistocated programing to evaluate the banks history in basicly the same way my brain does currently to come up with a state of charge.
I believe that the state of charge of a bank can be deternined once you start measureing stuff and paying attention to the charge discharge cycle. Basicly I intend to replace my anal monitoring of volts - amps - loads - charging with a program that does just that and accounts for the bulk - absorption - float isues of charging, the varance in capacity with battery temp, the varance in capacity with changing discharge rates, the battery internal resistance - AKA bat impedance and some other technical stuff. Knowing all the above and accounting for it as mentioned all i really want then is:
a) is the bank charging (i.e. solar - load = charge? or discharge?)
b) what is the current state of charge (so I know how far, based on past experience of looking at the thing, I can go.
If a fault (i.e. lots of AH in after float volts is achieved indicating a shorted cell as one simple example, or a loss of bank capacity based on AH out not being what i previously measured when the voltage got to some triger level being another) is found the an alarm is set and the user can "pull the codes" to see what the unit found. Perhaps an upgraded version would have some switching to stop the user from doing dumb stuff or keep dumb stuff from happening like my Cadillac turning off any thing left running 10 minutes after I get out of the car but that is down the road a piece.
I'd really like to keep the user interface simple as the cost of buttons and LCD screens and the problems with keeping them working and dry ...... really drive up the cost. I think I can build one for around $25 and sell them for $50
voltage history
current voltage
battery temperature
