Doug T.
Well, I think we learned a lesson or two yesterday. Four of us went out for a sail on Sunday. From the marina, the winds looked brisk but within reason. But, duh, the winds were WNW and we were on the western shore. Got out into the Bay proper and whoa, baby!!! 25-30, gusting over 35. (One guy at the marina claimed it was over 40, but I think his shredded jib was the cause for some slight exaggeration.) Tried sailing with the main reefed and genoa mostly furled (it's a 140), but we were still completely overpowered.- The rudder simply does NOT work when you're heeled over 40 degrees.- Two (or three) sets of reef points are mandatory in your mainsail- Make sure you have some extra turns available on the furling line. When you furl the sail while the sail is under a lot of pressure, the genoa wraps more tightly than usual and you'll hit the end of your furling line before you can get the sail fully furled. I saw several boats out there that encountered the same problem.- Jacklines and safety harnesses should be available and deployed when it looks at all rough -- you never know when you'll have to go to the bow to mess with the furler when the wind's blowing a gale- Lazy jacks would be real handy to have...- Baseball caps are not compatible with strong windsThomas Point lighthouse data:http://www.ndbc.noaa.gov/station_page.phtml?$station=tplm2
