SUN STAIN!
A
Alan
My Wife and I just bought a Catalina 25 that has two Lewmar brand portlights forward. On the inside is a plastic trim ring for each around the port each has become sunstained brown. There are NO replacemets available from Lewmar. I have tried the following products to clean off the brown: Simple Green, SOS pads,Clorox,Orange Clean,Westleys belche white,and Oxy Clean. I have run out of ideas. Anyone know of replacement parts source or a better cleaner? Thankss for your help! Alan 87 Catalina TR/SK
Dec 2, 1999
15,184
Catalina!
Alan: Everyone with a Catalina brags about the availability of Cat. part directly from Catalina. You should be able to get replacment parts directly from them. They supposedly have them for 30 yr old boats. They also have a catalog of available parts.
Dana,Mega 30
An idea,for plastic part
litely sand and paint,or maybe try a acid like lemen juice,or some thing on a small spot.
Robert Taylor
take em off
i removed the plastic covers on my 30 foot catalina. it gave the boat an industrial port look that i really liked. it is kind of a no b.s. look. if you think about it, they really don't do anything and are kind of a nuisance. rt
A
Alan
Thank You!!!
Thanks for your Information, I had not thought of Calling Catalina! Westleys Bleche white seems stronger than lemon Juice as the product Information says wear rubber gloves and dont inhale. Currently the trim ring rings have been off and it DOES have that industrial look. Sailnet called Lewmar and they stated that Lewmar has no replacement parts-very interesting. But for $167.00 each I could buy new Port Lights. I am going to try Catalina Thanks, I will let you know! Alan 87 Catalina 25 TR/SK #5612
Steve
Last resort... simple, yet it might work
I used Barkeepers Friend and Zud to clean the stained bottom (brown) of my dinghy and it worked really well with a "scrubby" sponge. Both these products contain oxalic acid which removes certain stains better than bleach. I would recommend trying that before scrapping the vents. (Plus, have you ever thought about PAINTING them?) Steve
A
Alan
Latest Update!
I thank everyone for their responses, I called Catalina Direct and spoke with Lowell, They do not have any. I had thought about painting but I prefer Not to. I do like the Barkeepers friend idea and will try that tonight and let you know. Again thanks for all your thoughts. Alan 87 Catalina 25 TR/SK #5612
Steve
Zud might be better
Just thought you might like to know. I went to Ace Hardware (True Value) and got Zud, which is a tiny bit more expensive than Barkeepers Friend, but I believe it is more concentrated with oxalic acid than the other. However, if you already HAVE the Barkeepers' Friend, then try it and it will give you some idea if it works. And I will readily admit... I got the information on cleaning those brown stains from guys on this great forum. Steve
A
Alan
Final Update
Tank you to all who gave me GREAT ADVICE, Last night I used Barkeepers friend-which I had,SOS pads and Soft Scrub with bleach and LOTS of Elbow grease. It has made a difference. I have to be gentile but it has made it alot cleaner and is almost back to the ivory color. Thanks for everyones help!
