While tending to issues on my recenly purchased 2004 Hunter 326, i noticed the Rule 650 sump pump, with internal, digital activation switch was only pumping when the momentary "Bilge Pump" switch was pushed. I thought it was broken but before replacing called Rule (yes, there is a person you can call there) and found out that the Solid Brown wire needs 12v. constant for this function. On my pump, that solid brown wire is connected to a brown/yellow wire that goes to the middle of three connections on the momentary "Bilge Pump" switch. Tested that line to find it dead. The middle connector on the "Bilge Pump" switch is always dead. I tried a lot of things with that switch that did not work.
My nave panel also has a switch labeled, "Bilge Pump." This also has a brown wire which gets 12v. when on, but I could not determine where it went. To my knowledge there is no "Sump Pump" (other than the Rule bilge pump) in my boat. DOES ANYONE KNOW WHERE THIS WIRE GOES OR IF THERE IS ANOTHER SUMP PUMP SOMEWHERE?
I connected a temporary jumper line from the switched-hot terminal on the "Sump Pump" switch to the brown/yellow wire that I disconnected from the middle terminal of the "Bilge Pump" switch. In exactly 2.5 minutes, the Rule 650 kicked in and drained the bilge. It ran empty for about 2 minutes and then shut off. This complies with Rule's YouTube video that states the 650 (and presumably the updated replacement, 760) issues a half-second start of the impeller every 2.5 minutes. If the impeller finds water, it pumps until all water is gone (presumably testing every 2.5 minutes of pumping time).
So...I am going to permanently install a jumper from the switched-hot side of the "Sump Pump" switch to the disconnected brown/yellow wire to the Rule 650 and leave that switch on when I leave my boat at the marina's AC-powered dock for long periods, thus protecting my boat from flooding by hurricane or small leak.
WHAT DO YOU FOLKS THINK OF THIS?
(Sorry for the perhaps overwritten document above - I like to explain stuff completely. Critiques of style welcomed.)
Quasimotor in Oriental NC
