My Oday 35 has a sump pump in the bildge that is seperated from the rest of the bildge. A hose from the shower and from the ice box leads into it and a hose leads out overboard at the stern. There is about a 4 inch high wall around the sump with a metal screen covering the top. There is no seperate bildge pump. I will be adding a seperate bildge pump but my questions are: How many gpm should I buy considering that the sump pump will act as a back up? Can I tap into the existing hose for the bildge pump or does it need its own hose? I suspect that the sump was an addition to the boat but I'm not sure. Do other Oday 34/35's have this arrangement?
