We have an Irwin 10/4 with Wire/rope halyards and all lines are controlled at the Mast.
I would like to run the Main Halyard and Topping lift to the Cockpit as an off season project.
Will probably run the Reefing lines and Lazy jacks (When i install them) also. Just looking for different ideas on how YOU have or would do this. The Main Halyard is wire to rope but there is plenty of line that the wire will never get to the bottom of the Mast. I don't intend to Pull the Mast this winter so don't want to install anything as a Mast Step. I'm thinking something simple like a Pad eye bolted to the Deck and attaching a snatch block...or maybe a few of those spring loaded stand up blocks that bolt thru the deck. Would it be better to attach right to the Mast, I was thinking I t would be best to NOT have that many holes screwed to the mast at the bottom.
What ever method I use to transition from the Mast to the Deck, I will also need Deck organizer then run to a rope clutch. I am trying to get a list together of how I want to do this then try to pick up the items over winter as I find good prices.
Thanks for your ideas and opinions .
Brian
Brian
