Suggestions for Haul Out near ST Pete FL.??
Sanman
Aug 28, 2006
109
- - Birmingham, AL
Hi All!
The wife and I are looking at a Catalina 30 down near Gulfport FL. We are going down for sea trials and survey in a couple of weeks, and need to find a marina within reasonable distance who can Haul the boat for an inspection of keel, rudder, through hulls, etc. We are relatively unfamiliar with the area so any intel and contact info on this would be appreciated!
Sailm8
Feb 21, 2008
1,750
Hunter 29.5 Punta Gorda
When you choose a surveyor he might suggest a marina. Mine suggested one and it was a good thing I used it because there was a mix up on the date to pull the boat. Luckily he knew the lift guy and they worked it out.
Aug 2, 2011
90
Newport 30 MKIII Madeira Beach, FL
Almost next door to Gulfport Marina by water is Maximo Moorings Marina. They are a full service marina and yard. I've never been hauled out there nor have I had work done there but I know people who have and it has a good reputation. By car it is a little more distant just because of the lay of the land but by no means far. Any local surveyor will be familiar with Maximo Moorings. Good Luck with you purchase.
Len
May 24, 2004
7,164
CC 30 South Florida
If the boat is inside Tampa Bay then a yard in Salt Creek will be the best choice.
May 27, 2004
2,041
I wouldn't go to Salt Creek unless there are bad reports on Maximo.
The one I used in SC was not reputable. The one that was, wasn't available at the time I needed to haul.
Sanman
Aug 28, 2006
109
- - Birmingham, AL
Thanks All!
Thanks for all the input, Y'all! Looks like we're going to haul her at Maximo.
