Suggestions - Barnacle removal
1,944
Catalina 310 #185 Quantico
Bottom line best process is to immediately pressure wash the hull when it is just out of the water and set on the stands. Then take a hand scraper and scrape the barnacles off. While they are still freshly out of the water they tend to come off fairly easily. Afterward you can just use a sander when you are prepping your bottom to pain. If you do that you don't need any chemicals.
